upwardcrayon's avatar
upwardcrayon
changed ssid name,no longer broadcasts signal
changed ssid name only, left rest of settings alone. Now it now longer broadcasts signal
  • William10a's avatar
    Mar 29, 2017
    are  the wifi leds lighting up if not on the back of the router you find a wifi on/off switch you said you had the wndr3400 v2 all three version have the switch on the back.of the router in the same place next the reset button.
