upwardcrayon
Mar 29, 2017Aspirant
changed ssid name,no longer broadcasts signal
changed ssid name only, left rest of settings alone. Now it now longer broadcasts signal
- Mar 29, 2017
are the wifi leds lighting up if not on the back of the router you find a wifi on/off switch you said you had the wndr3400 v2 all three version have the switch on the back.of the router in the same place next the reset button.
upwardcrayon
Mar 30, 2017Aspirant
Wanted to change ssid name to "virus.exe", that wouldn't work for some reason. Your reset suggestion worked, however at that point no connection wired nor wireless. Just changed back to PoliceVan, back to having wired and wireless. Any ideas why it wouldn't accept virus.exe for a name? Thanks
William10a
Mar 30, 2017Master
must have to do security software in the firmware did like the name virusareus probably would work.
