Raghad's avatar
Raghad
Changing IP settings
Hey everyone,   I tried to enter my router's settings to change the ip address, trying to make it work as an access point to extend another router's signal in my house. I guess i did something in...
  • ElaineM's avatar
    Mar 18, 2017
    Welcome to the community, Raghad
    Perhaps, you disabled the DHCP? If DHCP is disabled then the router will not provide you any IP address in order to access the admin page of the router. In order to access it, you will need to assign a static IP address on the computer. By the way, before disabling the DHCP make sure that you assign a static IP address on the router. Check out the link below on how to configure it as an Access Point.
    I’m setting up my NETGEAR router for the first time, how do I set it to Access Point (AP) mode?
