Raghad
Mar 17, 2017Aspirant
Changing IP settings
Hey everyone,
I tried to enter my router's settings to change the ip address, trying to make it work as an access point to extend another router's signal in my house. I guess i did something in...
- Mar 18, 2017
Welcome to the community, Raghad
Perhaps, you disabled the DHCP? If DHCP is disabled then the router will not provide you any IP address in order to access the admin page of the router. In order to access it, you will need to assign a static IP address on the computer. By the way, before disabling the DHCP make sure that you assign a static IP address on the router. Check out the link below on how to configure it as an Access Point.
I’m setting up my NETGEAR router for the first time, how do I set it to Access Point (AP) mode?
Raghad
Mar 19, 2017Aspirant
ElaineM
Mar 20, 2017NETGEAR Employee Retired
Raghad You may push the reset button on the unit to start from scratch. I suggest that you use a paperclip to push it to make sure that it's firmly pressed.
