rockjamd
May 04, 2016Aspirant
channel bonding c3000
Hello, THis is in regards to Netgear C3000 wireless modem I have had slow connectivity for couple days through comcast. I am wondering if it has to do with channel bonding. I checked wires, d...
- Retired_MemberMay 05, 2016
-22.9 is a problem, I would suspect water in a splitter or connector on the outside or a bad house amp. You need to call Comcast for a service call.
Retired_Member
May 05, 2016-22.9 is a problem, I would suspect water in a splitter or connector on the outside or a bad house amp. You need to call Comcast for a service call.
- rockjamdMay 05, 2016Aspirant
THanks for your help today I am getting better speeds do you think it is still a splitter or hardware problem? Last night I was only getting 5mbps and has been slow for couple days if it gets slow again I will call comcast. I am paying for 75 mbps
NetGear C3000
Date Download Upload IP Address
5/5/2016 10:53 AM 66.99 Mbps 12.23 Mbps 5/5/2016 10:52 AM 66.44 Mbps 11.99 Mbps 5/5/2016 10:51 AM 31.38 Mbps 12.14 Mbps 5/5/2016 10:50 AM 14.68 Mbps 12.04 Mbps 5/5/2016 10:44 AM 66.56 Mbps 12.14 Mbps getting more channels this morning: NetGear C3000
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 9 705000000 Hz -21.2 dBmV 28.5 dB 226859190 29606850 2 Locked QAM256 2 663000000 Hz -13.3 dBmV 31.4 dB 935504 176901 3 Not Locked Unknown 3 669000000 Hz 0.0 dBmV 0.0 dB 0 0 4 Not Locked Unknown 4 675000000 Hz 0.0 dBmV 0.0 dB 0 0 5 Locked unknown 5 681000000 Hz -13.2 dBmV 23.8 dB 2420 1039 6 Not Locked Unknown 8 699000000 Hz 0.0 dBmV 0.0 dB 0 0 7 Not Locked Unknown 10 711000000 Hz 0.0 dBmV 0.0 dB 0 0 8 Not Locked Unknown 11 717000000 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 57 5120 Ksym/sec 36400000 Hz 54 dBmV 2 Locked ATDMA 58 5120 Ksym/sec 29500000 Hz 51.7 dBmV 3 Locked ATDMA 59 5120 Ksym/sec 22600000 Hz 50.7 dBmV 4 Locked ATDMA 60 5120 Ksym/sec 15700000 Hz 52.5 dBmV - Retired_MemberMay 05, 2016
Call before it goes out completely and they tell you the earliest app is 3 days out. The test results don't mean squat they are a snapshot in time nothing else.
The signal levels show a problem deal with the problem.
- rockjamdMay 07, 2016Aspirant
comcst contractor came today. I found out they were here working on someone else last week and whatever they did to fix other apartment messed everyone else up. He said someone is comeing withing 48 hours to fix the main line coming in. Anyways all I can do is show this pic this is how the last tech left box on my apartment building one week ago. I have no idea what this is but he said it was messed up. This pic is how last tech left box....
So you were right to call comcast fast.
Thanks For help
