rockjamd
May 04, 2016Aspirant
channel bonding c3000
Hello, THis is in regards to Netgear C3000 wireless modem I have had slow connectivity for couple days through comcast. I am wondering if it has to do with channel bonding. I checked wires, d...
- Retired_MemberMay 05, 2016
-22.9 is a problem, I would suspect water in a splitter or connector on the outside or a bad house amp. You need to call Comcast for a service call.
rockjamd
May 05, 2016Aspirant
THanks for your help today I am getting better speeds do you think it is still a splitter or hardware problem? Last night I was only getting 5mbps and has been slow for couple days if it gets slow again I will call comcast. I am paying for 75 mbps
NetGear C3000
Date Download Upload IP Address
| 5/5/2016 10:53 AM | 66.99 Mbps | 12.23 Mbps | ||||
| 5/5/2016 10:52 AM | 66.44 Mbps | 11.99 Mbps | ||||
| 5/5/2016 10:51 AM | 31.38 Mbps | 12.14 Mbps | ||||
| 5/5/2016 10:50 AM | 14.68 Mbps | 12.04 Mbps | ||||
| 5/5/2016 10:44 AM | 66.56 Mbps | 12.14 Mbps |
getting more channels this morning: NetGear C3000
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Retired_Member
May 05, 2016
Call before it goes out completely and they tell you the earliest app is 3 days out. The test results don't mean squat they are a snapshot in time nothing else.
The signal levels show a problem deal with the problem.
