kovach
Jan 27, 2017Follower
Charter Intermittent Slowdown
I have an R6400 router. For the past week I've experienced intense slowdowns in internet speeds. Rebooting the modem seems to always fix it. Repairman came out and replaced everything fro...
- Jan 31, 2017
Hi kovach,
You can try isolating it by bypassing the router and connecting a computer straight to the modem then perform the tests. If the speed is consistently fast while connected to the modem from the same server then you can try the following:
1. Change the MTU
http://kb.netgear.com/app/answers/detail/a_id/19863
http://kb.netgear.com/app/answers/detail/a_id/25675
2. Reset the router
3. Re-flash the latest firmware then reset and reconfigure the router
Dexter
Community Team
DexterJB
Jan 31, 2017NETGEAR Moderator
Hi kovach,
1. Change the MTU
2. Reset the router
Dexter
Community Team
