Commoner
Oct 20, 2015Aspirant
Check/change UDB and TCP Port
Hello, I'm trying to connect my garage door opener to the Netgear wireless router. The garage door company said that I need to have the UDB port set to 80 and the TCP port set to 2165 in order fo...
- Oct 21, 2015Don't worry about port forwarding yet. You need to connect the garage door opener to the router's Wi-Fi network first.
Are you ever asked to enter the Wi-Fi password into the garage door opener? That would be necessary for the door opener to join. You do have a password configured for your Wi-Fi network, right? If not, then you should have one. Make sure to use WPA2 security.
Retired_Member
Oct 20, 2015What door closer do have? Make and model. Usally if UPNP is enabled in the router it should configure automaticaly
Commoner
Lift master 8550W
- TheEtherOct 20, 2015Guru
Did you follow the instructions in the manual to connect the garage door opener to your router? If you did, then skip this first paragraph. You need a smartphone or tablet (I suspect a laptop will work, too), to connect to the garage door's Wi-Fi network. Then, open a browser and visit setup.myqdevice.com to complete the process to connect the garage door to your router's Wi-Fi network. During this part of the setup process, you should not need to make any UDP or TCP port changes on your router.
Once you have successfully connected your garage door to your router's Wi-Fi network, you will proceed to download the MyQ app onto your smartphone or tablet and create an account. Once you are done, you should be able to control your garage door with the app while you are at home.
The app may not initially work while away from home. You can test this by turning off Wi-Fi and using cellular data. Warning, cellular data charges may apply. Haha, I sound like a commercial. If the app doesn't work, then you may have to open up a couple of ports on the router to allow the app to access the garage door. According to this FAQ answer, you have to open TCP port 8883 and UDP port 2165. It also mentions UDP port 80, but the wording is unclear.
In order to open these ports, you need to log into your router and set up Port Forwarding. You didn't provide the model # of your router, so I cannot provide specific instructions. If you have the manual, you can read the section on Port Forwarding to set it up. You can find the manual online at http://support.netgear.com by entering your model #. Basically, you will need to create 3 port forwarding entries, one for TCP port 8883, one for UDP 2165 and, possibly, one for UDP port 80. All three rules should specify the IP address of your garage door opener.
Again, try the MyQ app while away from home before you set up Port Forwarding. If the app works, then you can skip the Port Forwarding setup. If the app doesn't work, then set up port forwarding for TCP port 8883 and UDP port 2165, first. Add UDP port 80, only if the app still doesn't work.
Good luck.
- CommonerOct 21, 2015Aspirant
Hello,
I did follow the instructions in the manual for connecting to the garage door, and also with the garage door company over the phone, to no avail. I'm able to pull up the site on my mobile device where it looks for my router, but then it isn't able to connect to it. I have a dual band router and only one connection shows up in the list of available networks. Could that be an issue?
I'll try the suggestion you gave below for port forwarding and see how that goes. I'll keep you posted. Thank you for submitting the suggestion.
- TheEtherOct 21, 2015Guru
You say you connected to the garage door, but it's not clear if that meant you connected to the garage door with your mobile device or if you connected the garage door to your router's Wi-Fi network?
The garage door only supports 2.4 GHz, so it would only see one of the available networks provided by the router.
