Commoner's avatar
Commoner
Check/change UDB and TCP Port
  Hello, I'm trying to connect my garage door opener to the Netgear wireless router. The garage door company said that I need to have the UDB port set to 80 and the TCP port set to 2165 in order fo...
  • TheEther's avatar
    Oct 21, 2015
    Don't worry about port forwarding yet. You need to connect the garage door opener to the router's Wi-Fi network first.
    Are you ever asked to enter the Wi-Fi password into the garage door opener? That would be necessary for the door opener to join. You do have a password configured for your Wi-Fi network, right? If not, then you should have one. Make sure to use WPA2 security.
