rzona001's avatar
rzona001
Chromebook-Google Cloud Print
Can anyone provide some guidance on how to set up my Google Cloud Print using my Netgear Router?  I am following these instructions
http://download.brother.com/welcome/doc002896/cv_eng_gcp_a.pdf
and when I get to page 8 or 13 I get stuck.  I am able to get into my router admin settings but I don't know where I go to set up the Google Cloud Print.  I recently bought a Chromebook and this is the only way to print.  I have a brother printer that I know is compatible with Google Cloud Print.
Any help would be much appreciated.
Thank you!!
  • Thank you for responding!  I figured out my problem. I was using the IPS address. I was using my laptops address and not my printer's. I'm all set now. Thanks
  • The instructions you provided does not have page 13.  Can you be more specific about where you are getting stuck?  Have you entered your Google account information into the printer?
    • rzona001's avatar
      rzona001
