PulseFog
Oct 15, 2015Aspirant
Chromecast and Airplay connection problems on the Netgear wndr 4500v2
Hopefully someone is able to help me with two issues I am having based on Chromecast and Airplay. Chromecast problem: Hardware: OS Android Lollipop 5.1.1 on a Sony Xperia Z2, Windows 10 on a Len...
- Oct 19, 2015
The problem might be due to interference especially if both of you are on the same channel.
It is best recommended that you set different channel to avoid such problems.
Keep us updated and hopefully that fixes the problem.
PulseFog
Oct 18, 2015Aspirant
Interested in the story of isolation it kept me thinking. I have had new neighbours and it appeared they are broadcasting 2.4 ghz on the exact same band as I am doing on 11. Could it be that simple? I have changed the band to the most quiet one number 1. And that seems to solve the problems! I am having an Airplay icon on my iPhone. This was missing for two months until today. The same goes for the chromecast icon in Netflix and in the google toolbar. It all seems to work. I will test it tomorrow again and if it still works than I owe you many thank!
Keep you posted.
gr,
PulseFog
ElaineM
Oct 19, 2015NETGEAR Employee Retired
