GautierS49
Jan 21, 2022Tutor
CLI "unknow command"
Hello,
My compagnie has just provided me a NETGEAR GS108T and asked me to programmaticaly disable a specified port.
To do that, I need to do it manually first with CLI.
I have successfully connected to the SWITCH with telnet. According to a NETGEAR CLI user manual, I need to enter these following commands to disable a port :
#config #interface 1/0/2
#shutdown and other commands
But when I write "#interface 1/0/2" to access to the 2nd port, the switch reply "unknow command"
What did I do wrong ? Probably this model of switch is not compatible with all CLI commands ?
Thank you,
Gautier
you'll have better luck in the switches forum instead of the general router forum.
https://community.netgear.com/t5/Switches/ct-p/business-switches
Will do thanks !
Hope they've got some answers/help for you on there!
