Pacaron
Aug 06, 2018Aspirant
Cloned settings on old router to D6400
I have cloned the setting from old working router on to a newer (but used) D6400. I get invalid gateway, Cannot test DNS Fix adapter :en0 failed. error.. Is it a bad D6400 router?
Old Router is Actiontec .11g
Thank you for your very kind help and suggestions. Returning it as defective.
> used) D6400. [...]
Firmware version? Did you reset the settings on the D6400 before
beginning this adventure?
With my weak psychic powers, I can't see the settings on the old
router, or on the D6400.
> [...] I get invalid gateway, Cannot test DNS Fix adapter :en0
You get "invalid gateway", et al. from what, when you do what?
As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
That's a model number?- PacaronAspirant
NETGEAR D6400 AC1600 WiFi VDSL / ADSL Modem Dual Band Gigabit Router (using 2.4GHz – NETGEAR73)
It was reset to factory settings.
Firmware: 1.0.0.52
Settings on both (Actiontec GT724 WG) AND (NETGEAR D6400 AC1600 WiFi VDSL / ADSL Modem Dual Band Gigabit Router) is as follows:
As shown on System preferences - Network
TCP/IP:
Ipv4: 192.166.0.6
Subnet Mask: 255.255.255.0
Router: 192.168.0.1
DNS:
DNS Servers: 205.171.3.25 domain.actdsltmp
Hardware:
media access control (MAC) address: f4:5c:89:c2:4b:91
The Actiontec GT724 WG is working fine
Using Netgear Genie: on a
Apple Computer: Mac
Via hardwire ethernet cable through --Thunderbolt Ethernet is currently active and has the IP address 192.168.0.2.
MacBook Pro (Retina, 15-inch, Mid 2015)
Processor: 2.8 GHz Intel Core i7
Memory: 16 GB 1600 MHz DDR3
Wi-Fi: (copy/paste from system report)
Type: IEEE80211
BSD Device Name: en0
Hardware (MAC) Address: f4:5c:89:c2:4b:91
IPv4:
Configuration Method: DHCP
IPv6:
Configuration Method: Automatic
DNS:
Server Addresses: 205.171.3.25
Proxies:
Exceptions List: *.local, 169.254/16
FTP Passive Mode: Yes
Auto Discovery Enabled: Yes
IEEE80211:
JoinModeFallback: Prompt
PowerEnabled: 1
RememberJoinedNetworks: 1
RequireAdminIBSS: 1
RequireAdminNetworkChange: 1
RequireAdminPowerToggle: 1
Version: 2300
NETGEAR Genie: Clicked on Internet menu button and button ‘Fix It’. and this is displayed:
Fixing network. Do not carry out other operations.
09:06:26 Verify current location, please wait...
09:06:26 Location is not changed.
09:06:26 Fixing adapter:en0. Please wait...
09:06:26 Verifying there is an existed service on interface en0.
09:06:26 Verified service successfully.
09:06:26 Verifying interface en0's state.
09:06:26 Interface is up.
09:06:26 Testing wireless radio state, Please wait...
09:06:26 The wireless radio is turned off by software, trying turn it on.
09:06:27 Turned on the wireless radio successfully.
09:07:08 Testing the gateway...
09:07:08 The gateway is invalid.
09:07:08 Cannot test DNS.
09:07:08 Fix adapter:en0 failed.
Graphic shows connection from Computer to Router and not connected to Internet
On what, the "MacBook Pro (Retina, 15-inch, Mid 2015)"?
> TCP/IP:
> Ipv4: 192.166.0.6
> Router: 192.168.0.1
You left out "Configure IPv4: [...]". Is that "166" a typo, or an
actual (Manually configured?) problem?
> Using Netgear Genie: [...]
I've never touched any of the Genie apps, so I know nothing, but...
Having a client-device IP address of "192.166.a.b" and a Router with
an IP address of "192.168.a.c" might qualify as an invalid gateway.
Unless you need a fixed IP address for the Mac, you might have less
trouble if you specified "Using DHCP" instead of "Manually" (assuming
that that's what you did). And even if you did want a fixed address,
then you could reserve a particular (dynamic) address in the router's
DHCP server (ADVANCED > Setup > LAN Setup : Address Reservation).
