vrayevans
Nov 06, 2021Tutor
cm1000 > ac1750 download speed
I have a AC1750 with the latest firmware connected to a netgear cm1000. My xfinity contract is for up to 400 mps. When I plug my PC into the cm1000, I get those download speeds. When I connect the c...
- Nov 06, 2021
I would stick to that version for now. I've seen issues on the .118/.120 version.
Glad it worked!
If you mark it solved, it might help the next person
Nov 06, 2021Guru - Experienced User
What actual router is it? AC1750 is a the speed
what firmware is on the router?
What device are you testing on?
What site/app are you using for speedtesting?
Have you tried other devices?
Is IPv6 enabled?
