vrayevans
Nov 06, 2021Tutor
cm1000 > ac1750 download speed
I have a AC1750 with the latest firmware connected to a netgear cm1000. My xfinity contract is for up to 400 mps. When I plug my PC into the cm1000, I get those download speeds. When I connect the c...
- Nov 06, 2021
I would stick to that version for now. I've seen issues on the .118/.120 version.
Glad it worked!
If you mark it solved, it might help the next person
vrayevans
Nov 06, 2021Tutor
Hey, thanks much, that seemed to work.
Do I want to update to the latest firmare??
Thanks again
Nov 06, 2021Guru - Experienced User
Glad it worked!
