beechsport
Nov 23, 2020Aspirant
cm1000v2 how to mirror MAC address with existing ISP Modem
Have existing modem furnished by Spectrum and I want to run a new Netgear Modem CM1000v2 as well. Can I mimic the MAC address from the ISP modem with the new Netgear modem? Basically, can I run two ...
- Nov 23, 2020
Not sure how big your home is or what speeds you're needing.
I'd just make sure to go the triband one's. The dual band are decent but the tribands have a dedicated wireless backhaul for faster speeds/lower latency. You can also hardwire the satellites in if you'd like. Helps performace as well.
Nov 23, 2020Guru - Experienced User
beechsport wrote:Thanks, was trying to save the $49/month payment
Not sure how adding a 2nd modem would save $49 unless you were trying to piggyback on someone else's account.
beechsport
Thanks for asking. I have a current account with Spectrum, full package, tv, internet, phone. I have need for a second cable modem in another part of the house. Leaving the Spectrum furnished modem in place, wanted to just tee in to the cable line and install a second modem. Spectrum saying that I cant do that, and will have to pay for an additional line/internet access at $50 additonal per month. Why can't the second modem mirror/mimic the mac address for the Spectrum modem?
- plemansNov 23, 2020Guru - Experienced User
Because if they allowed that, all a person would have to do would be to clone the address and run as many modems on spectrums network as they wanted. You could add one at your neighbors, friends, family, etc.
If you're needing better coverage, check into triband mesh systems like orbi. You have a router and then mutliple access points throughout the home.
- beechsportNov 23, 2020Aspirant
Any recomendations? Seems there are a bunch of them.
