beechsport
Nov 23, 2020Aspirant
cm1000v2 how to mirror MAC address with existing ISP Modem
Have existing modem furnished by Spectrum and I want to run a new Netgear Modem CM1000v2 as well. Can I mimic the MAC address from the ISP modem with the new Netgear modem? Basically, can I run two ...
- Nov 23, 2020
Not sure how big your home is or what speeds you're needing.
I'd just make sure to go the triband one's. The dual band are decent but the tribands have a dedicated wireless backhaul for faster speeds/lower latency. You can also hardwire the satellites in if you'd like. Helps performace as well.
beechsport
Any recomendations? Seems there are a bunch of them.
Nov 23, 2020Guru - Experienced User
