tonyw97007
Jan 30, 2022Aspirant
CM1150V &RAX80 & AX1800 howto monitor data per ip address
howto monitor data per ip address! I need to figure out who/What is using a lot of data. Comcast is telling me we are using a lot more data and I need to figure out what devices / people are do it. ...
tonyw97007
OK If Netgear does not have a solution. Does anyone have a idea how we can do this? I do not want to but if I have to I will look at other routers I know some do have that ability. I am hoping Netgear and or Armor can add that ability to track Data per ip.
Jan 31, 2022Guru - Experienced User
You can do it with 3rd party firmwares.
Snag a cheap (ish) router that supports ddwrt and go
CM1150V--->ddwrt router----->RAX80 in access point mode.
ddwrt has add ins that support individual monitoring but you'd need to do some modifications to do so. There's older routers that support ddwrt that you could pick up for pretty reasonable.
