jazzman4
Oct 21, 2021Aspirant
cm1200 trying to connect to wifi router c6300
 will not connect and unable to get wifi  Wanted to upgrade my speed and just purchased the CM1200.  works fine when direct connected to PCs, but cannot get it to connect to the router/wifi Netgear c6...
Oct 22, 2021Guru - Experienced User
A couple things.
1. The C6300 is a modem/router combo devices.
2. the CM1200 is a modem only device. it has no routing capability. Meaning even though it has 4x ethernet ports, most ISP's will only allow 1 device to connect to it because they only assign 1 public ip address.
If you're planning on using the cm1200, you'd need a router to connect to it. The C6300 isn't just a router. its a modem/router combo device. So its doesn't have a WAN port to connect to the CM1200.
Not sure who helped you figure out what to buy but they steered you poorly.
Advice?
I'd pickup a router to connect to the cm1200. Its a solid modem that needs a router connected to it.
I don't recomend buying modem/router combo devices because then you run into issues like you're having when you upgrade. As well as then the ISP controls the firmware.
- jazzman4Oct 22, 2021AspirantIs there a "first choice" router that would work with the cm1200? We need to cover 1500 sq ft.. and it needs to connect to a mesh wifi system for our family next door (two unit building with a total of 2800 sq ft. Also, is wifi 6 backward compatible? - FURRYe38Oct 22, 2021Guru - Experienced UserYou can review these links about Orbi MESH systems: https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/highlight/true#M91216
 https://www.netgear.com/orbi/default.aspx
