jazzman4
Oct 21, 2021Aspirant
cm1200 trying to connect to wifi router c6300
 will not connect and unable to get wifi  Wanted to upgrade my speed and just purchased the CM1200.  works fine when direct connected to PCs, but cannot get it to connect to the router/wifi Netgear c6...
Oct 22, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
Wanted to upgrade my speed and just purchased the CM1200. works fine when direct connected to PCs, but cannot get it to connect to the router/wifi Netgear c6300. Iv'e rebooted, tried going through my 8-bay switch, tried many configurations rebooting each time. I can see my old wifi network name, but will not connect.
