jazzman4
Oct 21, 2021Aspirant
cm1200 trying to connect to wifi router c6300
 will not connect and unable to get wifi  Wanted to upgrade my speed and just purchased the CM1200.  works fine when direct connected to PCs, but cannot get it to connect to the router/wifi Netgear c6...
jazzman4
Oct 22, 2021Aspirant
Is there a "first choice" router that would work with the cm1200? We need to cover 1500 sq ft.. and it needs to connect to a mesh wifi system for our family next door (two unit building with a total of 2800 sq ft. Also, is wifi 6 backward compatible?
Oct 22, 2021Guru - Experienced User
You can review these links about Orbi MESH systems:
https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/highlight/true#M91216
https://www.netgear.com/orbi/default.aspx
