pktierney99
Mar 03, 2021Aspirant
CM2050V Availability
The CM2050V cable modem is the only model shown on the Xfinity site for 1.2Mbps and voice. But, I can't find it anywhere for purchase. Does anyone know if it is truly for sale and where to get one? I...
Mar 03, 2021Guru - Experienced User
They tend to go out of stock rapidly when they become available. covid has caused many shortages.
pktierney99
Thanks. I was assuming that was the case. I'm still trying to get ahold of the Netgear Sales Team to see what options exist.
- plemansMar 03, 2021Guru - Experienced User
Are you wanting the 2.5g port?
otherwise your other option is the cm1150v
- plemansMar 03, 2021Guru - Experienced Userit uses wan port aggregation for up to 2gig speeds. 1gig if not using wan port aggregation.
- pktierney99Mar 03, 2021Aspirant
The real issue is Xfinity -- they are stating the CM1150V won't support their 1.2Mbps stream. In part I think because the firmware update required isn't supported for the 1150V (I've also seen that in the Netgear literature). I want to connect it to a mesh network and keep the max data transport speeds at all three of the nodes (hard wire to the ethernet ports on the mesh network). I don't think the 1150V will support this option at the 1.2Mbps speed.
