wyoming
Feb 11, 2018Follower
CM400 Cable Modem seek to plug into DSL N600 Router 3700v2
ALL equipment NetGear; DSL N600 is working fine ( also WiFi) on DSL N600 DGND3700v2 DSL Router wifi CM400AZNA Modem CM400 lacks instructions for this. Only have Chromebook, so Netgear Diagnostics not ...
- Feb 11, 2018
> [...] CM400AZNA Modem CM400 lacks instructions for this. [...]
What's unclear? The CM400 User Manual explains how to connect it to
a "Computer, router, or WiFi router" (page 8, figure 6). The DGND3700v2
User Manual shows how to connect it to a "Fiber/Cable modem" (page 20,
figure 7).
Visit http://netgear.com/support , put in your model number(s), and
look for Documentation. Get the User Manual(s). Read. If mysteries
remain, then ask specific questions.
> [...] Is this just a simple plug in and play ?
Define "simple".
antinode
Feb 11, 2018Guru
figure 7).
Define "simple".
