JK-VA's avatar
JK-VA
Guide
Jan 12, 2021
CM400 suddenly very slow
Xfinity cable internet. Paying for 100 mbs. Usually getting 100-115. Last 36h suddenly dropped to 9 mbs. CM400 5y old. Of course Xfinity says nothing wrong on their end. Delivering appropriate speed. Typical response of must be old modem and needs replaced. Happened one other time about 1y ago and it was a setting on their end. Have reset modem and router with no change. Can anyone help me with checking the modem? See attachment
  • plemans's avatar
    I didn't see an atachement.
    do you have a screen snip of the cable connections page and the modem logs?
    Those help check the signal. xfinity is notorious for their first response being "its not the line"
    You can click on "choose file" and add them that route so we can see them right away. Otherwise a moderator has to approve them.
    Also, if you have any cable splitters, attenuators, amplifiers in the coax line, remove them.
    Check the line for kinks, bends, damage, loose/old/bad connections
    • JK-VA's avatar
      JK-VA
      Guide
      Sorry I did choose file. It just didn’t load.
      • plemans's avatar
        Do you also have your logs?
        You've got errors in the line. I'd check the line and remove any splitters, amplifiers, or attenuators. Check the line for kinks, damage, bad/cheap/old/loose connectors.
