deanosauruz
Sep 12, 2021Aspirant
CM500 Cable Modem Downstream Constantly Flashing Green
My Modem Details: Hardware Version C312T00-01 Firmware Version V1.01.12 Cable Modem Serial Number 48L50B7FA3805 CM Certificate Installed CM M...
Sep 12, 2021Guru - Experienced User
Your logs are indicating line issues.
do you have a screen snip of the cable connections page?
Check for splitters, signal attenuators, and amplifiers in line. Remove them if you do.
check the line for kinks, damage, old/loose/bad/corroded connections and replace them if needed.
I'd move the modem to right where the coax enters the home and connect it there.
- deanosauruzSep 14, 2021Aspirant
After checking the cables I find no erosion ordamaged cables, and I do not have any splitters, signal attenuators, and amplifiers.
the modem is as close to the coax entry point as physically possible.
Could there be a damaged line outside?
I speed test and i get acceptable speeds yet sometimes a website on my desktop will show a DNS failed page buit then within seconds suddenly appears to load the page....
I have attached a screen capture of the connections page- deanosauruzSep 14, 2021Aspirant
For some reason the attached image didn't appear with my reply.
- plemansSep 14, 2021Guru - Experienced User
your cable connections page looks pretty good.
What router do you have the modem connected to?
- deanosauruzSep 15, 2021Aspirant
I have an Archer A6 https://www.tp-link.com/us/home-networking/wifi-router/archer-a6/v2.8/
