deanosauruz
Sep 12, 2021Aspirant
CM500 Cable Modem Downstream Constantly Flashing Green
My Modem Details: Hardware Version C312T00-01 Firmware Version V1.01.12 Cable Modem Serial Number 48L50B7FA3805 CM Certificate Installed CM M...
deanosauruz
Sep 14, 2021Aspirant
After checking the cables I find no erosion ordamaged cables, and I do not have any splitters, signal attenuators, and amplifiers.
the modem is as close to the coax entry point as physically possible.
Could there be a damaged line outside?
I speed test and i get acceptable speeds yet sometimes a website on my desktop will show a DNS failed page buit then within seconds suddenly appears to load the page....
I have attached a screen capture of the connections page
deanosauruz
For some reason the attached image didn't appear with my reply.
