Wheetboi
Jan 25, 2021Follower
Cm500 slow
Hi I'm getting super low speeds on my Cm500 (barely out to 5mbps upload and download) I have a tech agent coming tomorrow but wondering what I can do now to troubleshoot. Here's some files from the...
Jan 25, 2021Guru - Experienced User
For troubleshooting?
Look at the coax line in the home for splitters, amplifiers, or attenuators. Remove them if you have them.
Inspect the coax for damage, kinks, moisture, bad/old/loose/cheap connectors and replace them if you do.
I usually tell people to directly connect the modem to where the line enters the home. That prevents any of the wiring in the home from being an issue.
In terms of your screen snip, you didn't include the upload or the modem logs. those are key for checking the line as well.
