jackpodsedly
Aug 01, 2020Aspirant
CM500
Will the CM500 work on a frontier DSL? I can not find this info anywhere--
- > I am going to get a EAX80. [...] - Why? That's an extender. What would you be extending with it? - > [...] Would it be wise to buy a modem also? [...] - If you have DSL service, then I'd expect that having a DSL modem and
 a router (possibly combined in one unit) whould be prety much required.- > [...] I keep reading that the stuff you get from the internet - > providers are junk. - Perhaps. However, you seem to have almost no idea of what you need,
 and if you get some kind of modem+router combination from your ISP, then
 at least it ought to work, and you'd know to whom you could complain if
 it doesn't.- Then, if you have some actual problem with whatever they provide, you
 might start looking for solutions to that actual problem.
 Or, you could just buy a random collection of various expensive
 gizmos, slap them together, and hope for the best. Note, however, that
 if your (unspecified) DSL connection speed is unspectacular, then the
 fanciest router/extender/whatever in the world might make little
 difference in your Internet experience.- Appropriate "junk" might serve you better than inappropriate
 treasure.
- > Will the CM500 work on a frontier DSL? [...] - The CM500 is a cable-TV-type modem, not a DSL modem. So, no. - > [...] I can not find this info anywhere-- - Where did you look? Did you ask Frontier? I'd bet that they know. - jackpodsedlyAspirantI am going to get a EAX80. Would it be wise to buy a modem also? I keep reading that the stuff you get from the internet providers are junk. - > I am going to get a EAX80. [...] - Why? That's an extender. What would you be extending with it? - > [...] Would it be wise to buy a modem also? [...] - If you have DSL service, then I'd expect that having a DSL modem and
 treasure.
