LWeber4
Dec 20, 2020Tutor
CM700 and R6400
I just connected a CM700 cable modem to replace a CM400. I have an R6400 router. When I run the speed test in my Nighthawk app I get 210mbs download and 15mbs upload from my 200mbs service, but an Oo...
- Dec 22, 2020
They were about 10-15ft from the router. They got about 35mbs. I decided to replace the r6400 with a Google Nest Wifi system connected to my CM700 modem. Thank you for trying to help, but I just don't have the knowledge or experience to deal with the settings, etc. I'm heading toward simple.
LWeber4
Dec 20, 2020Tutor
Thank you. The tests are wireless. I did suspect my router could be the problem, but I wanted some confirmation from people more knowledgeable than me. That includes most people!
Dec 20, 2020Guru - Experienced User
Wireless speeds maybe slower on your older router. Also depends on your wireless device that your using.
Wired speeds should be to spec however. WIred will always be better than wireless.
