HOJIN14018
May 15, 2020Aspirant
CM700 WON'T POWER UP
Need some insight. Modem was working fine...maybe a bit sluggish, but that could have been the provider. Then it stopped working. In fact, the modem will not turn on now. I'm about to contact service...
- May 16, 2020
you can try a different power supply.
it should be a pretty standard power supply so if you check some of your other devices, you can try one and see if it is that.
just make sure its got the same voltage and polarity. it can have more amperage.
May 16, 2020Guru - Experienced User
If its plugged in and not a single light is on, something failed.
there's things you can try but I'd go through your warranty option first so you don't void the warranty.
HOJIN14018
May 16, 2020Aspirant
Yes, it was plugged in with no lights showing anywhere. Looks like the warranty only lasted 1 yr from purchase. Any other suggestions?
I'm suspecting it's completely fried and will need to get a new cable modem
- plemansMay 16, 2020Guru - Experienced User
- HOJIN14018May 17, 2020Aspirant
Tried another power supply, but no luck. Looks like the modem went bad. That's too bad. It should have lasted another 2-3 yrs. Thanks for your suggestions. I'm going to look for another modem
