Thomas1026
Jan 19, 2021Aspirant
Coax adapter
Can this https://www.ebay.com/itm/2pcs-BNC-Female-to-RJ45-Male-Adapter-Coaxial-Barrel-Coupler-Connector-US/193606266241?hash=item2d13d52d81%3Ag%3AGxgAAOSw--1fLgz1&LH_BIN=1 be used to connect to the c...
antinode
Jan 19, 2021Guru
> Can this [...] be used to connect to the coax to connect to this [...]
"the coax"? _Which_ "the coax", from _where_?
What, exactly, are you trying to do? If you're asking whether a $5
thimble-sized gizmo can replace a cable-TV modem, then the answer is no.
I can't (yet) see your (second) picture. In-line images must be
approved by a moderator before others can see them. The time required
varies. Attachments have no such limitation. Of course, attachments
have their own one-per-message limitation.
- Thomas1026Jan 20, 2021AspirantThe Coax cable coming into the house. What other coax would I be talking about? Oh yeah. The one coming out of my TV. I want to hook the TV to a router and send messages to Mars! I have family up there. I need to speak with! Puts adapter in box!
- antinodeJan 20, 2021Guru
> talking about? [...]How should I know? With my weak psychic powers, I prefer to go by
the information which you provide, not by my guesses about invisible
stuff.My _guess_ was that you expected some $5 thimble-sized gizmo to
replace a cable-TV modem, which suggested that you might not be very
bright or well educated. Your response to a simple question ("What,
exactly, are you trying to do?") did nothing to refute that speculation.But feel free to provide some useful information, if you can.
- Thomas1026Jan 21, 2021Aspirant
I left two links there. One with a picture of the modem and one with a picture of an adapter. I mean come on? Why is that a hard question? The adapter says it converts RJ45 to RF.
- Thomas1026Jan 23, 2021Aspirant
not
