Thomas1026
Jan 19, 2021Aspirant
Coax adapter
Can this https://www.ebay.com/itm/2pcs-BNC-Female-to-RJ45-Male-Adapter-Coaxial-Barrel-Coupler-Connector-US/193606266241?hash=item2d13d52d81%3Ag%3AGxgAAOSw--1fLgz1&LH_BIN=1 be used to connect to the c...
antinode
Jan 20, 2021Guru
> The Coax cable coming into the house. What other coax would I be
> talking about? [...]
How should I know? With my weak psychic powers, I prefer to go by
the information which you provide, not by my guesses about invisible
stuff.
My _guess_ was that you expected some $5 thimble-sized gizmo to
replace a cable-TV modem, which suggested that you might not be very
bright or well educated. Your response to a simple question ("What,
exactly, are you trying to do?") did nothing to refute that speculation.
But feel free to provide some useful information, if you can.
Thomas1026
Jan 21, 2021Aspirant
How about this information. If you can't pull those two links. Look at the picture and answer a question. Then I'm pretty sure, I dont want you to answer a question anyway! I'm almost postive your not intellegent enough.
