Thomas1026
Jan 19, 2021Aspirant
Coax adapter
Can this https://www.ebay.com/itm/2pcs-BNC-Female-to-RJ45-Male-Adapter-Coaxial-Barrel-Coupler-Connector-US/193606266241?hash=item2d13d52d81%3Ag%3AGxgAAOSw--1fLgz1&LH_BIN=1 be used to connect to the c...
antinode
Jan 19, 2021Guru
> Can this [...] be used to connect to the coax to connect to this [...]
"the coax"? _Which_ "the coax", from _where_?
What, exactly, are you trying to do? If you're asking whether a $5
thimble-sized gizmo can replace a cable-TV modem, then the answer is no.
I can't (yet) see your (second) picture. In-line images must be
approved by a moderator before others can see them. The time required
varies. Attachments have no such limitation. Of course, attachments
have their own one-per-message limitation.
Thomas1026
Jan 23, 2021Aspirant
not
