Marcel13's avatar
Marcel13
Initiate
May 12, 2020
Combining Orbi RBK23 and R6220 to access external USB Drive
I had a Netgear R6220 router with a USB Storage connected.   Now, I have bought and installed the Orbi RBK23 and placed the R6220 in AP Mode, so I can still use it as a common Switch to support cab...
  • antinode's avatar
    May 12, 2020
    > [...] I cannot find a way to connect to the USB Storage.
       "cannot" is not a useful problem description.  It does not say what
    you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
    > What I cannot find anywhere is if the R6220 in AP Mode still supports
    > the USB Storage? [...]
       I don't see why it wouldn't.  But the R6220-as-wireless-access-point
    would normally have a non-default (LAN) IP address.  Assuming that the
    R6220-as-WAP is using DHCP to get its new (LAN) IP address, you might
    want to A) reserve a particular address for it on (the DHCP server on)
    your main router, and B) use that address to access the storage server.
