slsnyder348
Jan 04, 2021Aspirant
Commercial Electric plug won't connect
N300 wireless router WNR2000v3
slsnyder348
Modem is Netgear ADSL2 + modem DM111PSPv2
When the app SP1 tries to connect to my Netgear it says connection failed, try again. I have reinstalled app, reset internet and smart plug, turned phone off, etc. I know the app and plug work because it connected right up at my daughter's house. Also have a Google mini which works just fine.
Jan 04, 2021Guru - Experienced User
This wasn't much clearer than the rest.
Your trying to connect a smart/plug switch and it doesn't connect?
you have a DM111PSPv2 connected to the wn2000? is that correct?
but having issues with a smart plug
- slsnyder348Jan 04, 2021AspirantI am trying to connect a smart plug to my wifi and it won't connect. There is no problem with my wifi because I checked with my provider. I gave you the model numbers of my modem and router and have included the error that I receive each time.
- plemansJan 04, 2021Guru - Experienced User
you have the DM111PSPv2 connected to the wn2000?
the dm111pspv2 has its own integrated router as well. It can cause a double nat situation. That can sometimes cause issues setting up new devices.
- slsnyder348Jan 04, 2021AspirantSo the modem has it's own router?
