JennO123
Apr 03, 2018Aspirant
Comparability of Panasonic hardrive recorded with mobile router
I am wanting a mobile device to provide wifi to Panasonic hard drive for recoding Netflix as well as iPhone and I pad and a non iPad device. Not tech savvy which is probably obvious so need advice on ...
- Apr 08, 2018
Hi JennO123,
Welcome to the community!
1. Do you already have an Internet Service Provider?
2. If yes, do you already have a device supplied by them? What device is it and how is it connected?
3. If you are specifically looking for a mobile router/hotspot, we recommend contacting support for your ISP since they may have specific models that work with their network.
Dexter
Community Team
DexterJB
Apr 08, 2018NETGEAR Moderator
Hi JennO123,
Dexter
Community Team
- JennO123Apr 09, 2018AspirantHello DexterJB
Thank you for your response but after contacting Panasonic they, like a couple of other replies suggested I contact an internet service provider. They then told me about mobile wifi and I will be buying one of the products that their network supports. The Panasonic is wifi enabled so that solves my question
Regards
