JennO123
Apr 03, 2018Aspirant
Comparability of Panasonic hardrive recorded with mobile router
I am wanting a mobile device to provide wifi to Panasonic hard drive for recoding Netflix as well as iPhone and I pad and a non iPad device. Not tech savvy which is probably obvious so need advice on ...
- Apr 08, 2018
Hi JennO123,
Welcome to the community!
1. Do you already have an Internet Service Provider?
2. If yes, do you already have a device supplied by them? What device is it and how is it connected?
3. If you are specifically looking for a mobile router/hotspot, we recommend contacting support for your ISP since they may have specific models that work with their network.
Dexter
Community Team
DexterJB
Apr 08, 2018NETGEAR Moderator
Hi JennO123,
Dexter
Community Team
JennO123
Apr 09, 2018Aspirant
Hello DexterJB
Thank you for your response but after contacting Panasonic they, like a couple of other replies suggested I contact an internet service provider. They then told me about mobile wifi and I will be buying one of the products that their network supports. The Panasonic is wifi enabled so that solves my question
Regards
Regards
