Dolomiti99
Oct 04, 2023Follower
Compatibility Araknis Access Points
Just purchased a nearly new townhome 1900 sqft 2 floors. Home has an araknis router and 2 araknis access points. Araknis is currently controlled by an alarm integrator using OVRC. My netgear rout...
michaelkenward
Oct 04, 2023Guru - Experienced User
Check here for previous references to this brand:
Search - NETGEAR Communities – Araknis
My netgear router is actually 6250 not 6260 ( 6250 not listed in forum menu).
Probably the R6250, or possibly the R6250v2.
