Mel_Amboy
Sep 16, 2019Aspirant
Compatibility of my D6400 modem/router with my Providers New Requirements (TDS)
Our internet provider is requiring the following to continue use of our own D6400 modem vs renting theirs. I'm not sure if the D6400 has all of the following requirements: 1) G.992.5 (Annex M) 2...
- Sep 17, 2019
I assume that the new ISP is also DSL.
There is support for the D6400, including a manual and data sheet, somewhere at the end of this link:
>>>> D6400 | Product | Support | NETGEAR <<<<
This should provide you with most technical specifications.
michaelkenward
Sep 17, 2019Guru - Experienced User
- Mel_AmboySep 19, 2019Aspirant
Thank you. Found most of what I needed in the manual.
Any idea if "G.998.x (bonding)" might have another nomenclature? It was the only thing I didn't find reference to in the manual.
- michaelkenwardSep 19, 2019Guru - Experienced User
No idea. Does your ISP have a compatible-modems list? Or a user forum where you can ask other customers?
- antinodeSep 19, 2019Guru
> [...] Any idea if "G.998.x (bonding)" might have another nomenclature?
https://en.wikipedia.org/wiki/G.992.5
