RonBuck's avatar
RonBuck
Compatible or Replace?
I have Model R6400 Nighthawk AC1750 router. I occasionally have signal drops at farthest points from the router. I am buying a Nighthawk Mesh WiFi 6 (MK62) system, and wzny to know if the R6400 can fu...
  • FURRYe38's avatar
    Oct 24, 2022
    No, the R series router doesn't support any MESH features. The MK system would be a big upgrade from the 6 series.
