RonBuck
Oct 24, 2022Aspirant
Compatible or Replace?
I have Model R6400 Nighthawk AC1750 router. I occasionally have signal drops at farthest points from the router. I am buying a Nighthawk Mesh WiFi 6 (MK62) system, and wzny to know if the R6400 can fu...
- Oct 24, 2022
No, the R series router doesn't support any MESH features. The MK system would be a big upgrade from the 6 series.
Oct 24, 2022Guru - Experienced User
RonBuck
Thanks "Furrye38"!!
Really appreciate your quick, expert reply!
- FURRYe38Oct 25, 2022Guru - Experienced User
Hope you get something good.
I do like my MK63 system.
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
