wjs2017's avatar
wjs2017
Follower
May 01, 2017
Computer #3 does not connect with this router. Computers 1 and 2 are connected fine
Dear Sir of Madam: I have two computers (Computer 1 and 2)  that are interfacing OK with this router. Computer #3 does not want to connect with this router. When trying to access the internet from C...
  • DexterJB's avatar
    May 01, 2017
    Hi wjs2017,
    You can try removing the saved network profile from the computer (assuming it is connecting via WiFi) and reconnect then enter the correct WiFi password. Check the link below for the steps.
    https://kb.netgear.com/20055/
    Dexter
    Community Team
