notAtechie2
Jan 19, 2022Follower
Computer won't recognize wifi/router N300 wifi cable modem router C3000
My Dell laptop has completely stopped recognizing that my router and wifi signal exist. I can see my neighbors' wifi signals, but can't find mine despite other electronics connecting without a proble...
Jan 20, 2022Guru - Experienced User
Easy way to check if its a router problem. Try a different device. Can the other devices see your routers wifi?
- michaelkenwardJan 20, 2022Guru - Experienced User
As I read the first message:
can't find mine despite other electronics connecting without a problem.The answer to that key question is yes.
- plemansJan 20, 2022Guru - Experienced User
michaelkenward whoops, read it to fast :)
thanks for the correction.
got a cheap usb wifi adapter you can plug into the laptop to test to see if its the laptop's wireless card causing the issue?
Worth having ine of those lying around for just this purpose.
