notAtechie2
Jan 19, 2022Follower
Computer won't recognize wifi/router N300 wifi cable modem router C3000
My Dell laptop has completely stopped recognizing that my router and wifi signal exist. I can see my neighbors' wifi signals, but can't find mine despite other electronics connecting without a proble...
michaelkenward
Jan 20, 2022Guru - Experienced User
plemans wrote:
Easy way to check if its a router problem. Try a different device. Can the other devices see your routers wifi?
As I read the first message:
can't find mine despite other electronics connecting without a problem.
The answer to that key question is yes.
michaelkenward whoops, read it to fast :)
thanks for the correction.
got a cheap usb wifi adapter you can plug into the laptop to test to see if its the laptop's wireless card causing the issue?
- michaelkenwardJan 20, 2022Guru - Experienced User
Worth having ine of those lying around for just this purpose.
- wcalifasJan 20, 2022Prodigy
restart your computer and see if that helps, also disable your wifi adapter and wait a little bit then enable it back on in the control panel for the devices.
