notAtechie2
Jan 20, 2022Follower
Computer won't recognize wifi/router N300 wifi cable modem router C3000
My Dell laptop has completely stopped recognizing that my router and wifi signal exist. I can see my neighbors' wifi signals, but can't find mine despite other electronics connecting without a proble...
michaelkenward
Jan 20, 2022Guru - Experienced User
plemans wrote:
got a cheap usb wifi adapter you can plug into the laptop to test to see if its the laptop's wireless card causing the issue?
Worth having ine of those lying around for just this purpose.
wcalifas
Jan 20, 2022Prodigy
restart your computer and see if that helps, also disable your wifi adapter and wait a little bit then enable it back on in the control panel for the devices.
