aidar's avatar
aidar
Configure Netgear DG834G v4 as a regular Wired+Wireless Router (without ADSL)
I’ve got Netgear DG834G v4 “Wireless ADSL2+ Modem Router” (https://www.netgear.com/support/product/DG834Gv4.aspx). It has - 4 ethernet ports 100Mbps - 1 ADSL port - Wireless antenna for 54 Mbps Wi...
  • antinode's avatar
    Jun 19, 2020
    > [...] it would be nice if Netgear had a verified solution for this
    > simple use-case.
       Perhaps, but it would be unrealistic to expect Netgear to do anything
    for this slow, weak antique.
       As a general-purpose router, there may be no real hope.  You might be
    able to configure it as a (slow, weak) wireless access point (because
    that's possible for almost any router).  See, for example:
          https://community.netgear.com/t5/x/x/m-p/1463500
    That's written for a Netgear C6300-as-WAP, but the steps are about the
    same for any other router (any make/model) which lacks a one-step WAP
    option.
