cktan's avatar
cktan
Follower
Dec 19, 2023
Configure R6300 as second router
Hi all,
My office is spacious, requiring more than one WiFi router for complete coverage. I have both R6300 V1 and V2 routers that I intend to set up as the second and third routers, respectively, extending from my primary router. After configuring the wireless settings on both R6300 V1 and V2, I connected their Internet ports to my main router. Although this setup is typical for other routers, it doesn't seem to function properly on my Netgear routers. The reason for establishing distinct routers is to cater to different departments, each having its own network for file sharing. I prefer having two separate networks rather than a shared one to maintain departmental distinctions.
Thanks,
CK
  • michaelkenward's avatar
    michaelkenward
    Not really. You shouldn't try to put two routers on your network, regardless of who made them.
    Two routers on your network can cause headaches.
    What is Double NAT? | Answer | NETGEAR Support
    When you say "extending from my primary router", do you mean that the R6300 V1 and V2 are plugged into the main router?
    If so, the easiest option is to put both added routers into AP mode. That turns off the router bit of each device.
    How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
    If this really is essential, you need to work out how to create separate subnets. There was an article in the KnowledgeBase to help on that front, bit like many it seems to have gone AWOL.
    How to configure two NAT capable devices | Answer | NETGEAR Support
    The question remains valid, but it seems that Netgear doesn't want you to know about it.
    Doubtless one of the true exerts here will jump in with details from that missing article.
    • plemans's avatar
      What speeds do you pay for?
      Reason I ask is that router was released over a decade ago. It was a rock star when it was released but has been far surpassed in terms of performance.
      It might be time to look at upgrading. And if you need something with more than a single router, upgrading to a mesh solution might fix your issue and do a lot better with coverage.
        michaelkenward
        "Rock star" might be pushing it. But good point.
        At least it was Gigabit Ethernet, unlike some models in that range.
        Certainly not something to inflict on an office with more than a handful of wifi clients. And fancy things like separate networks could be easier with newer hardware.
