Jno2's avatar
Jno2
Tutor
Nov 09, 2020
Configure R6400 to accept a Linksys wrt54g 1.1 as an access point
I have my R6400 as a primary router. I want to use a Linksys wrt54g v1.1 as an Access Point.
Using an ethernet off my R6400 I get speeds above 200ghtz.  I have done all the  recommended setup for the Linksys as an AP I can find, but  my speed on the Linksys AP (on ethenet abt 50 ft away) is only around 50ghtz.
I  must be missing something.  Any ideas? Do I need to  configure a setting on the R6400 also?
Thanks.
  • > Model: R6400|AC1750 Smart WiFi Router
       Is that accurate?  R6400 or R6400v2?  Look for "Model" on the product
    label.  Firmware version?  Connected to what?
    > [...] I want to use a Linksys wrt54g v1.1 as an Access Point.
       Ok.
    > [...] I have done all the recommended setup for the Linksys as an AP
    > I can find, [...]
       With my weak psychic powers, I have no idea what you "can find", or
    what you did after you found it.
    > Using an ethernet off my R6400 I get speeds above 200ghtz. [...]
       "speed" of what?  Between what and what?  Measuered how?  "ghtz"?
    "Gb/s"?
    > [...] my speed on the Linksys AP (on ethenet abt 50 ft away) is only
    > around 50ghtz.
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual (at least).  Read.
    Look for the LED descriptions.
       What does the (LAN) port-status LED on the R6400[vX] indicate for the
    connection between the R6400[vX] and the Linksys WRT54G?
       Were you expecting to get speeds above 100Mb/s through the WRT54G?
    Did you look at its specs?
          https://www.linksys.com/us/support-article?articleNum=142393
          6. Does the Internet connection of the router support 100 Mbps
          Ethernet? [...]
    > [...] Do I need to configure a setting on the R6400 also?
       I can't immediately think of any.
    • Jno2's avatar
      Jno2
      Tutor
      label.  Firmware version?  Connected to what? Book says R6400;    Firmway V1.0.1.62_1.0.41,   Connected to  broadband modem with Ethernet.
      Ok.
      > I can find, [...]
      what you did after you found it.  Changed last group in IP address to .1.200;  Made SSID same as intended R6400 address, "wireless 2.4"; Disabled DHCP.
      "Gb/s"?  Opps, I meant 200+ mbps from R6400 to /thru any of my  Ethernet ports.
      > [...] my wireless speed out of the Linksys AP (on ethenet abt 50 ft away) is only
      > around 30 mbps (or less).
      Look for the LED descriptions.    I have the book that came with it.
      connection between the R6400[vX] and the Linksys WRT54G? If I connect my laptop to the Ethernet port, running to the desired room, the speed is 200+ and the R6400 LED is off. If I connect the WRT54G and access my laptop by wireless the spped is <30 and the LED is amber.
      Did you look at its specs? Answered    below
            Ethernet? [...]   The specs say it does accept speeds up to 100mbps.  I was hoping for more than 20-30. Is that only wishful thinking or is there something that's not right??????????
      Thanks for your input.
      • Jno2's avatar
        Jno2
        Tutor
        Trying to use a Linksys-G router as an access point (hardwired to my R6400).
        Looking it up online it says: " Shares a single Internet connection (10/100 WAN) with 4 Ethernet wired (10/100 switched LAN";   "Max. Link Rate:54 Mbps".    I'm not sure what that means.
        Can  someone help me understand how that affects that it transmits?
        > Is this why my Ethernet speed coming out of the Liksys is under 54mbps? I figured that meant speed of the wireless but not through the ethernet coming out of it.
        Thanks
