gvasick
Jun 11, 2017Aspirant
Configuring R6300 as an access point after firmware upgrade
 Hi,     I installed a firmware update this morning on my R6300 router (I am not sure how to tell if I have a v1 or v2 model):     Firmware Version  V1.0.2.80_1.0.59     After the update, there is no ...
- Jun 12, 2017That is it. The access point configuration is under "Use other operation mode" at the bottom of the screen shot. Thanks, George
gvasick
Thanks for the tip. Mine is a version 1.
I could still use some help with configuring it as an access point after the firmware update.
Thanks,
William10a wrote:On the bottom of the router you will find a label with a the model number if follow by a v2 or other version that the version of the model you have.
R6300 without a version number is a version 1, if you have say R6300v2 you have a R6300 version 2, and so on depening on how many versions for that model.
George
William10a
Jun 11, 2017Master
Here is answer from a few months ago https://community.netgear.com/t5/R6000-Series-AC-WiFi-Routers/Is-AP-mode-in-R6300v1-possible/td-p/1231636
The last poster tells how the R6300v1 in a access point mode.
- gvasickJun 12, 2017AspirantThat is it. The access point configuration is under "Use other operation mode" at the bottom of the screen shot. Thanks, George - William10aJun 12, 2017MasterI'am happy that the community could help.
