gvasick
Jun 11, 2017Aspirant
Configuring R6300 as an access point after firmware upgrade
 Hi,     I installed a firmware update this morning on my R6300 router (I am not sure how to tell if I have a v1 or v2 model):     Firmware Version  V1.0.2.80_1.0.59     After the update, there is no ...
- Jun 12, 2017That is it. The access point configuration is under "Use other operation mode" at the bottom of the screen shot. Thanks, George
William10a
Jun 11, 2017Master
Here is answer from a few months ago https://community.netgear.com/t5/R6000-Series-AC-WiFi-Routers/Is-AP-mode-in-R6300v1-possible/td-p/1231636
The last poster tells how the R6300v1 in a access point mode.
gvasick
Jun 12, 2017Aspirant
Thanks,
George
- William10aJun 12, 2017MasterI'am happy that the community could help.
